Project Mass Effect
I think ym pants just got a bit tight down there.... and i need to know one thing, WHERE DID YOU GET THOSE CONTROLLERS!?
EDIT: I guess i must've overlooked that. BTW is it hard to mod a 360 controller with new buttons etc?
Extremely tidy rig!
You just need a TORX T8 security screwdriver (or I think a 2mm flathead will work to if you angle it correctly) to open the pad and then it's very easy to swap out stick/buttons
Yea like sps said its easy as flip. But id advise the torx screwdriver it takes the annoyance out of it. But i you want to replace the analogue switches you had better get someone to give you a massage and get you a nice hot chocolate cos its gonna drive you insane. But on the whole its easy and fairly cheap to do
I might look into that then...
And again LOVELY rig! I am simply in love with it...
<--- Huge Mass Effect fanboy right there.
Here is a pic of my custom made XSPC bay res faceplate and some new faceplates for my lamptron fan controllers. Hopefully will recieve them tommorow .
Looks awesome. Took some inspiration from you and modded a couple of XBox controllers myself recently.
