"Project Freeman" Retro 3dfx gaming build
Small update. Today i did some work for the drivebays. Its pretty heard to get it right and i need to do lots of filing to get it done.
I did lots of work on the front this weekend!
The filler is used and i measured the front fans cutout.
The cd player is installed and below you see the clips from the front.
You cans ee the m5 threads to hold the front in place. And i used rifets and metal plates to put the 2 front pieces together.
Detailshot of the frontclip.
Tomorrow i gonna buy a 114mm roundholesaw :cool:
Yeah the front panel is finaly gonna look like it should be :) I apllied allready some filler so the 2 panels will become 1 panel again :D
I used alot of filler to make the upper parts of the front panel :D
First layer of primer to see where i need more filling and sanding.
Small update!
Hardware testfit!
I also changed some hardware in the config!
Pentium3 500
512mb pc133
Matrox g400max instead of matrox g450
2x Voodoo2 Sli
3com 3c905b instead of netgear nic
Awe64 Gold isa
