Project BRW (Black Red White)
Geralt
Hi All,
finally registered here (although I've been watching TTL videos for some time). So this is my new build I just completed. Still waiting on frozenq tri spiral res. anyways I hope you will enjoy it:
Specs:
CPU-I7 4770k 4.4GHz
RAM-16 GB Corsair Vengance Pro Red 1866Mhz
Motherboard-Asus Maximus VI formula
GPU-GTX 570
SSD-Samsung Evo 250 GB
HDD-3x 1TB WD caviar black
Case-Corsair Obsydian 750d
PSU-cooler master real power 620W
WC:
CPU: XSPC Raystorm
GPU: EK Full cover Nickel
Pump: laing ddc1t+ with xspc res top
hose: Primochill primoflex LRT 3/8" ID
coolant: XSPC blood red
Rads: Swiftech qp320 and 240
Looks pretty nifty. A right angle fitting on the front rad would've been slightly cleaner. Maybe move or put a new light strip on the top, because there's a big dark spot in the top-right corner. Small things, but overall, very well done!
thanks Samdzig, i have another 2 strips of leds on order and as mentioned before frozenq res so it will be brighter. Will report back once i get then
Changed lighting and added frozenq res.
Yes I know CCFL is too big but its a temp one while replacement arrives (I've managed to brake the original one).
Also - Yes its being held by cable tie but that was the only way I could secure it the way I wanted it
Camera doesn't seem to be doing justice to the red color tho. In real life looks alot better
It would look better if there was white lighting, instead of red, because red lighting tends to wash out the entire case in a red glow (which I find undesirable) Is that a non-modular PSU, because there seems to be a bit of a clutter near the bottom of the case. Overall, its a nice build, but that res stand out a bit to much for my liking. Again, you could fix this with white lighting imo.
I had it with white (see pictures in 1st post) and tbh I like it with red better. The res stands out as atm there is blue CCFL in it but I will get an UV one so it wont be standing out that much. Like I said the camera doesnt do justice
Alright then, to each his own, I suppose :D
