Ok most of you probably know it by now and here we go for the first stage :
The program will have 2 Modes :
Advanced User
Home User
In these modes you will answer different questions which bring you to your best system.
So what do we need ? easy we need questions. Because the program will start out with the Home User i need you guys to think about questions that the user is asked to answer. Please keep in mind you are speeking to a PC Noob.
The questions schouldnt be more then 20.
Just post them in the right order please. Thanks
-> Everyone who helps even in this small survey will be mentioned on the webpage.
Some Q's i thought of (This is the format you schould write your ideas in)
What would you use your PC For mostly ?
- Office Applications (MS Office etc.)
- Media Applications (DVD Station etc.)
- Gaming station
- Server Station (HTTP Servers etc.)
heres what happens in the background for each of them :
-> choose Intel processor and Intel Board. Choose low GFX Card. Choose fast HD
-> choose Region free and fastr DVD Burner. Quiet Fans and HD. Low graphic card.
-> choose AMD Processor. choose fast GFX Card. Choose 1 Gb of ram, choose fast HD
-> choose fast Hd. choose 512 MB RAM
Depending on what the user chose he will get to the next question.
BIG Thanks if you are participating
Advanced User
Home User
- Gaming station
