Project Arcturus by PEXON
It deffo needs something in there to jazz it up, it looks a little drab. I'm going to cut some small lengths of MDPC-X later and mess around with some patterns.
Hey guys, sorry for the lack of updates, I've been really busy with work, plus no sign of the watercooling gear as of yet, so not a lot of progress can be made yet...
I managed to have a play around with the 24 pin however and I found that a few strands of MDPC-X Vivid Violet and a shake up with the pattern works wonders breaking the cables up and made them pop a little better. I am planning on integrating more Vivid Violet in one way or another and perhaps adding some light purple/ lilac fluid... hmmm.....
Also had to do a bit of bodging with the top rad, even though the case is massssive, the top will only really support a 30mm thick rad and a set of Scyth 12mm fans in order for me to get a nice cabling job on the 8 pin showing through....
Small MDPC-X Cable clamps and some stainless countersunk screws later...
Cheers for stopping by!
