Problem with my Razer Deathadder
Aela H
Hi
I don't know if this is the right forum section for it as I'm pretty new here but I'll ask anyway.
I bought this mouse not long ago and the problem being with the scroll, not sure if it's a common problem or not.
As soon as I'm in any browser, and I want to scroll up per 1 "tick" I do of scrolling upwards it sometimes (quite often) goes back down 1 tick and when I do multiple "ticks" upward its like having a seizure on the screen but does go up a bit. I find this extremely annoying when browsing on the web is there any way to solve this aside from throwing this mouse away?
Some says its a driver issue with W7, and that a previous version should work. However, many also reports its simply a common issue with the specific mouse, and should simply be replaced/returned.
If its new, return it and get a different brand. Razer is overpriced and isnt any better than other brands such as Logitech and Microsoft.
