crystalfat
Preparing and fitting an AMD FX easymod kit for the Prometeia. (ASUS A8N32SLI NF4 DELUXE)
Quick note: I have not checked the spelling or grammar of this in minute. OKAY LOZ!!, also the pictures are dodgy quality because the're off my phone as my trouble n' strife stole my camera.
Ok first here’s a checklist of what I used:
http://www.ldistudios.com/temp/Photo-0034.jpg
Use the conformal coating to cover the motherboard circuitry around the edge of the chip socket. (If using spray take care to mask the entire socket and all other peripheral sockets so no coating enters them)Make sure you don’t get and actually on the socket. I did around a 2-3 cm wide thin coating. Please not the lever arm need to be able to move so make sure it’s free of the coating.
http://www.ldistudios.com/temp/Photo-0035.jpg
Do the same with the back of the motherboard where the socket is. This conformal coating protects all of the components from condensation and it hardens. I then left this to dry for a few hours.
http://www.ldistudios.com/temp/Photo-0036.jpg
Place some dielectric grease on the socket
http://www.ldistudios.com/temp/Photo-0037.jpg
And then spread it around the pinholes with your finger moving the arm up and down a couple of times.
http://www.ldistudios.com/temp/Photo-0038.jpg
Stick your chip in, it may take a slight push once aligned because of the dielectric grease in the holes, take care not to bend any pins. I placed it in and then removed it and re-seated it, to spread the grease a bit. Close the lever arm, this may be a bit sticky but it should go down no problem.
NEVER USE FORCE ON COMPONENTS.
http://www.ldistudios.com/temp/Photo-0039.jpg
Cut some neoprene around the edges of the socket. I cut them quite thin so when the mounting bracket is placed on the mobo it fits snugly outside the neoprene.
http://www.ldistudios.com/temp/Photo-0040.jpg
The back plate for the easy mod kit is aluminium. (Bonkers if you ask me). Place the heater inside.
http://www.ldistudios.com/temp/Photo-0041.jpg
This must not touch your motherboard. Seal string should provide that needed gap, I don’t trust it though so here’s what I did. Simply place electrical insulating tape around the protruding bracket edges.
GET THE ORIENTATION OF THE PLATES CORRECT BEFORE FITTING. LINE THEM UP WITH THE EVAPORATOR HEAD BRACKET AND SEE WHICH WAY THEY SHOULD GO.
http://www.ldistudios.com/temp/Photo-0042.jpg
Place the seal string around the edges.
http://www.ldistudios.com/temp/Photo-0043.jpg
Line up the holes and press firmly onto the mobo (check orientation)
http://www.ldistudios.com/temp/Photo-0044.jpg
Place seal string around the front mounting bracket
http://www.ldistudios.com/temp/Photo-0046.jpg
http://www.ldistudios.com/temp/Photo-0045.jpg
Screw in the back plate till it bites then go careful and make sure you don’t over tighten them
You should be ready to fit you prommie as normal.
If this helps one person then that’s enough for me.
Cheers me dears
chris
P.s Please let me know if you think i missed anything
Special thanks to Maverik-sg1, fatty and K404.
Chris
http://www.ldistudios.comhttp://www.ldistudios.com
- Easymod kit
- Conformal coating (Dow Corning)
- Dielectric compound/grease
- Sheet of Neoprene 3mm thick
- ASUS A8N32SLI NF4 DELUXE mobo
Cheers me dears
chris
Chris
