N nick25 Guest Jul 16, 2005 #21 Yeah the Zippy only has 1 12v line put put out 45A I think it goes under the name of EMACS
M maverik-sg1 New member Jul 16, 2005 #22 Zippy 700w and PCP&P used with DFI NF4 Mobo need a jumper review to work correctly - if you are using the 4v DIMM. Both of which are fantastic unit to have. Cheers Mav
U unreal New member Jul 16, 2005 #23 maverik-sg1 said: Zippy 700w and PCP&P used with DFI NF4 Mobo need a jumper review to work correctly - if you are using the 4v DIMM. Both of which are fantastic unit to have. Cheers Mav Click to expand... Isnt that the same jumper trick which means you use the rails of the PSU 3.3 and so eliminate heat from top right mosfet?
