Highland3r
Need a new PSU for the X2/7900GT rig, initial thought was Seasonic S12 600w, but the older revs (and some of the newer it seems) appear to be having issues with the DFI's. That and the split 12v rails are a bit of a put off.
Next option was another 520w Powerstream, but they seem almost impossible to find in the UK at the moment...
So, current thinking is a Tagan TG580-U22. The 12v rail can be combined to run 32A which should be beefy enough. Only slight concern is with the 5v rail, its rated to 30A, compared to the 40A on the 520w Powerstream. However the Seasonic is also rated to 30A, so its probably not much of an issue..
Anywho, anyone using a TG580 at the moment? Whats the droop on the rails like? General thoughts etc.
Would another Powerstream be a better option (having said that, could swap the Tagan over to the Dothan rig if required, its not exactly high draw....)
PP&C are not an option btw. As much as i'd like one 150 quid for a 510 SLI is a little over budget, + need something thats quite quiet...
Cheers
Cheers
