Hey there guys, got my Tri-X 290 through today and (obviously) started to overclock it. I got to 1100/1500 easily, all fine. Then, I set the core to 1150, artifacts as soon as I start the benchmark. So I stop and turn the volts to +20. Then start valley again, yah no artifacts... but my card is throttling... even though its still very cool.
After a lot of faffing about I have found that if I set the core to anything higher than 1110 OR the volts to anything higher than stock, the card throttles its core clock... I honestly have no idea why, this is a screenshot of my last run of valley.
Currently set at 1100/1500 with stock volts and +20 power, its the best I can achieve without the core throttling for (what I can see) to be no reason.
Is it the GPU or the PSU having problems? as you can see the 12V rail drops to 11.63V whilst running, sometimes even down to 11.5! Even at idle its only 11.75, is this a sign my PSU is being crap? I have no idea really.
Also, the VDDC (which I assume is core volts, with the other being aux) is only about 1.08V during the run! I thought stock boost volts on this card were 1.18V?! I have seen it go up to 1.12V sometimes during the run, if the scene is not exactly intensive, and GPU-Z says the max it has recorded is 1.195V, but I am pretty sure that was right at the start of the run for just a split second.
Temps are well in order, GPU never goes higher than 79 and VRM temps are around 85c max and 55c max
P.S PSU model is in my sig, I am using sapphire TRIXX to overclock, have tried MSI AB, does the same thing. I have not tried using the force constant voltage or disable ULPS options in either pieces of software, no idea if that will change anything, will do when I test again soon.
So yeah, I am pretty worried guys. I hope my PSU is ok (and I hope the GPU is too since its brand new!)
