Hi all,
I am messing about with cable routing for my scratch build and have been using my old 775 motherboard as a template for positioning things. I just wanted to do a quick sanity check as if I mess this up I will not be pleased
Am i right in thinking that the CPU and mobo power connectors will be in the exact same place on all ATX motherboards? I looked at the ATX specification and I think that is what it was saying but I wasnt sure. Is it possible that on some mobos they will be moved around a little?
I would use the motherboard I am actually going to use but I havent ordered it yet (slight cash flow issue) and aside from that there may still be steel dust/filings hanging around that I dont want to get in it.
Cheers guys.
Cheers guys.
