I still don't have a proper desoldering station either. I've got a really good RS branded sucker which seems to do the job very well.I'm going to re-cap my AV32 at some point. Been pricing up Nichicon gold vs Rubicon and Audio Note.
Need to get a proper desoldering station first though. There are far too many to want to spend hours and hours digging at holes with a wick and sucker.
Sweet stuff enjoy putting together the new lego's
I've found while my 6800XT overclocks nicely that in general use for long periods of time i leave it on auto default any of the profiles i use give me minor stabilty issues feel it's down to drivers atm thou to be fair it's far better than it sounds.
I'll be intrested to see what clocks you get 2550mhz is as far as mine will go my cpu for sure holds it back, but you with your fancy 5950X I'm sure you will fair better![]()
If my poor little bwain can remember I'll let you know the results whence it arrives![]()
Well buddy mine will sure get a workout on my 3440x1440 144hz monitor, this card should drive it beautifully and I got great news this morning my stuff shipped! the cards landed in Aus earlier than expected so excited right nowWell auto default is what is working sweet for me, think it's cause when using the presets as the card is an AIB OC it doesn't like going at lower clocks so it's all over the show when using them, or at least the settings used in them presets are not right for my card.
I think your get higher mhz than me thou and for sure better fps in general my card performs best when something is more demanding but at 1440p 144hz most games I play are above 100fps even something like BFV with raytracing is around 80+fps avg, your more likely to get better fps with that CPU thou without doubt.
When gaming mine is boosting to 2400mhz pretty much all the time it's a really nice card thou and suprisingly quiet hardly ever has the fans turned on unless in port royal it's really weird so used too hearing jet engines lol.
I was half expecting driver issues, but they have been very minimal in general and the actual layout of the menu and UI I really like, the 6800XT is way too powerful for a 1080p monitor thou it for sure wants more work to do![]()
I'd only recap anything that is pretty close to parts that get hot. 12 years isn't that long in the swing of things with good quality capacitors. I've had amps over 30 years old that still have perfectly functioning electrolytic capacitors as they don't get hot and aren't heavily stressed.Kei - it's currently running Rubicon. They are original, hence my thought of re capping it (it's got to be at least 12 years old).
http://www.awdiy.com/index.php?page=tag-mclaren-av32r-dp-op-amp-replacement-2
I shan't be doing the op amps or what not.
So it looks like I didn't win the silicone lottery with either product as my chip does 4.8 and the GPU does 2300 still I'm happy enough just to have them.
CPU sounds alright, but the GPU should be able to do more than 2300 with an OC.
