Dicehunter
Resident Newb
A 3rd Corsair ST100 for my headphones on top of my case so I have 1 x for my 770s, 1 x for my 990's and 1 x for my Void Pros', I really like these things, They are built like tanks and add a nice subtle glow
I threw mine away, since the lighting to it didn’t work. Corsair software literally sucked ass. I literally had to have it opened up on my desktop everytime I wanted it to light up in the colour I wanted. Did I minize it, it went back to the standard rainbow effect.
The best part is, I couldn’t even save a lighting profile inside the software. So everytime I opened it up, I had to re-dial every setting over and over again. It ended up just doing my head in.
Why didn't you just send it off to Corsair to get it fixed ? It's obvious you had a faulty one.
How can I send off their own software to them?...
It wasn't the software it was the device, I have CUE open right now and can change the lighting to anything and it stays just fine even when I close to the notification area.
I had the same problem and it turned out to be the USB socket of the ST100 which was causing issues.
He is saying you have to have the software open so it keeps his settings. As soon as you exit the software it goes to default. Same thing with the keyboards and mice. It's pretty bad software honestly. I can't even program macros for application launches without having the software open. It's dumb as dirt. What the hell is the point of having onboard profile storage if it doesn't even let me do half the crap I want? I don't want to have the software minimized. I do not want to waste system resources for things I don't need.
I know what he said but he said he minimised it not exited it.
iCUE runs quietly in the background when you close it to the system tray, No point in closing the program down fully as it uses next to no system resources, 0.8% CPU and 80MB memory, It's a non issue.
I don't care if it is or not. The fact is I cannot close without losing functionality I need because it needs to be open. It's a waste of my recourses for bad software. I run the minimal amount of apps I need at all times. Having an RGB keyboard software open is annoying
Well to be fair, it was both having it minimzed and closing it. Lost settings and it switched back to default, by both.
If I hated a particular software this much I simply wouldn't buy their products ^_^
Don't understand why you turned to passive aggressive attitude. Literally no way of knowing if this problem exist without owning it. Reviewers never mentioned anything about It.
Well their products are good, just their software that’s crap ^_^
That's going to look great Dice. Will we see pictures once it's done?
