I will buy one and some spray paint
Can someone give me a link to buy the mouse?
Ive disabled the acceleration on my gigabyte m6880 mouse yesturday, i got used to it over few hours and now i like it.
They look like the mice when I was in college, they were good enough for local LAN's on CS Source.![]()
We've got one of these mice in work and they feel so cheap and nasty and uhhhhhh no get it away, Kill it with fire ^_^
Lol, the basic small mice I always found best for gaming, I can't game with all this bulk, new shapes and buttons.
You used to be a razer nut, you should be used to cheap and nasty gear.
Shots fired.
It will probably feel very cheap, but if the sensor is the best then i can deal with that.
Cheeky git ^_^
That being said though the Razer Mamba and Corsair M95 both have optional polling rates.
The M95 has polling rate options from 125Hz, 250Hz, 500Hz and 1000Hz *1ms, 2ms, 4ms or 8ms* and DPI settings ranging from 50 to 8200 using it's Avago 9800 sensor.
The Razer Mamba I don't have a clue about my I know it performs very well.
DPI are often falsy considered to be an indicator of the quality of the sensor. My Rival could be running at 6500 DPI 1000hz, but who needs 6500 DPI. I'm using 400 atm.
The WMO may only support 400 DPI, but with the USB port overclocked it apparently beats pretty much every gaming mouse. Especially laser mice are overrated, laser sensors aren't that accurate.
But the DPI on the M95 can go as low as 50 which is very helpful in certain scenarios not forgetting to mention all the optional polling rates.
I've just switched from a Kone Pure Laser, to a Kone Pure Optical last week.. enjoying the accuracy and lack of hardware acceleration so far, although it doesn't work on anywhere near as many surfaces lol.
I cringe everytime someone uses a mouse without a mousepad anways. Those scratches in the feet of the mouse! Terrible.
Which mouse pad do you use out of curiosity ? I got myself a Corsair MM2200 Extended and an OCUK Mega Mat XXL, This thing is HUGE.
Not my picture but gives you an idea of the sheer size of it -
I used to have a Corepad XXXL (maybe XXXXL, can't remember). 90x45cm, but it was also like 3.5mm thick, feels like a towel. So i now bought a Steelseries QcK+, 45x40cm, 2mm thick. Pretty happy with it, would buy again.
:rollinglaugh: See if that razer is still going in 13 years like my original wmo's. (pre 1.1a's)You used to be a razer nut, you should be used to cheap and nasty gear.
Shots fired.
