remember300
Active member
Samsung external Blu-Ray Drive
Intro
Working in an electronics store to give me some pocket money while at uni has its ups and downs, The main down is seeing things and wondering if you need it ... needless to say i "needed" alot of things i probably did not need, I did want a Blu-Ray drive for my pc to play films while writing coursework out and to have my headphones on to not disturb the land lord at 3am.
The downside to having an optical bay i found was it ruined the look of some cases both in and out, so i thought hmm what about an external drive.
Specs
Connects via USB 2.0 for data and for power, the cable is USB A to USB A Mini, which might need extending if you plan to put it more than 50cm away from the nearest port.
Physically its not much bigger than 3 CD cases stacked on top of each other
Additional software
To read disks is one thing to play movies etc you will need software, This unit comes with software from cyber link to read DVD's and BL disks it will also play films in 3d depending on the type of display you have i have tested Drive Angry on an active stereoscopic display and was very impressed with it running at 24 FPS.
Extra information.
The drive can also be used as a blu-ray player for TVs with a usb port as an AV player, which is an added bonus.
Also i have tested the drive upside down and works well, so if your thinking of getting this then putting it under the desk hidden so you can access it at anytime this is an option too
Needs XP SP2 onwards to run
Pricing
This drive was bought for £99.99 but has been seen on the net with offers and such for around £70.
Further information
Downside apart from cost is if you use Cyber link It messes with the volume and is only affected by master control. Other than that i'm more than happy with this little unit.
And here is it playing "Highlander" while i was floating on the forums
Intro
Specs
Additional software
Extra information.
Pricing
Further information
