Please recommend PSU and watercooler
That Kama Meter is sexii :yumyum:
For reservoirs though if your going for something cool looking I'd get this
http://www.petrastechshop.com/ekmure.html
As for tubing Tygon is nice but wait till Frag gets on later because he has some tubing that he loves and says beat the pants off Tygon.
1/2 vs 3/8 I'm not sure about. I always thought the more water the better cooling. You wont have to worry about bending it too much because you have a large case so tight bends won't be a problem.
i use 7/16" ID Masterkleer tubing its a lil smaller than 1/2 and bigger than 3/4 and fits perfect on 1/2 barbs. its said to be the best performance.. but i havent seen any tests, i use it b/c it bends well, its cheap, dosnt kink and its bigger than 3/4.
XSPC High Quality 3/8" is pretty nice
get.php
get.php
name='kerochi' said:
Thnx everyone!
Is Masterkleer made out of PVC? And is the material/thickness/durability/flexibility close to this
http://www.arcticmod.com/computer-m...d-pvc-tubing-38-id-58-od-for-38-id-tubing.htm
I kinda like the design. But if it's not reliable then i guess ill go for the Masterkleer.
So is there some consensus that 7/16" and 3/8" is the way to go?
Please consider that the pump gauge of the D5 is 1/2"!
As stated the tubing you were looking at probably isn't the best and will most likely be too stiff. If your pump and cpu block are both 1/2" then I'd just get 1/2" tubing or 7/16" ID Masterkleer seeing as AI says it works a charm on 1/2" barbs :)
ok.... oh, if 7/16" is smaller than 1/2 than wouldnt there be a slight risk of leaks occuring???
Just wondering..........
No less actually, the fit will be tighter (ID=inner diameter) . Either way you should use some jubilee clips and do them up nice and tight (there are alternatives but i prefer to put my faith in jubilees)
And to make them easier I put the ends of the hose im very warm water for a minuite or two and it becomes easy to install.
wow cool advice!!
am i missing out on anything else?
what are the advatages of having a reservoir and do you think i need one?
oh yeah and a question about tube length and water amount: is more better and how much more?
wow cool advice!!
u wont use 12 ft, but more is better and ull be cutting it, 10ft @ min, i use around 7 or so in my loop.
wow cool advice!!
A reservoir will make life easier in the long run in terms of filling the loop and general looks.
More tubing is worse really, it puts more strain on the pump and longer to warm up in the case (cases ambient temp is bound to be slightly higher than outside). The later is probably negligible due to the usual wall thickness of decent tubing.
And I buy in 3M lengths :)
UV dye is optional, usually decreases temps h/e proboly not enough to effect performance, but if u crunch on everything to drop temps u should be able to oc more. i would use penotosin they have blue and red or if u wanna be safe fluidxp(its expensive h/e ppl that have had leaks are proud they bought it). im sure others have their own opinons but this is my 2 cents.
This is my first time at watercooling and building a new pc so thnx for helping out everyone.
I have another question about the setup of the rads at the front.
Would it make more sense to get one huge 360mm rad instead of just buying another 120mm rad to go on top of the 240mm rad I already have?
(or would i get the 120mm rad and just not plug it in as part of the watercooler setup?)
