is there a way to lower ur ping while playin a game, i finally got off my a$$ and hooked up my xbox to the internet to play some halo through xbconnect my average ping i would say is between 90-100 but sometimes it jump up to 300-400 during gameplay....soo ya
im limited to ISP, only two in my area, 1 cabe and 1 dsl, and to see what my ping is im just goin by what it shows on my pc screen when i have my xbconnect running while playin halo
It's tough to get a steady playable ping over Xbconnect... I remember when it first came out and getting on a forum discussing the benefits/downfalls to it.
The biggest downfall to the whole internet play system on games that aren't made for XBL is that they aren't designed to be playable with pings over 5-10ms since you don't get anything higher on a local network. I gave up on Xbconnect about a week after it came out, no need for it anyhow I had 4 xbox's setup at the house for gnarly tournament action
Yes, as Dav0s says, connecting to local servers will be better for pings, and cable is usually better. However a ping of 400 is terrible, and 56k would probably be better than whatever your on .
ill try to stay to the closer severs to my area to help, i have dsl since i dont like cable and the ping of 400 or so is rare but i did see it a couple of times
Its possible that your adsl provider uses the BT Datastream network, which isn't as good as the IPStream network that is now more commonly used, which provider are you with?
