jamesriley94
Hi,
I bought a second iiyama X2377HDS (third will probably follow) but the pictures between the two are not identical.
The screen connected through DVI is bright, whilst the one through HDMI or DVI to HDMI adapter doesn't seem to be able to achieve the same kind of brightness and in comparison looks dull and grey.
Anyone any ideas how to fix this? Settings for each are exactly the same, except for the HDMI / DVI cables.
Or is the only option getting a DVI cable? (stupidly left all my spares at home)
To follow on from this;
If / when I get a third monitor, how would I go about connecting this to my 670 if it is going to be different through HDMI? Or do I then need to go through display port adapted to DVI? and would that then need to be active?
Thanks in advance...
I'm sure I'll have missed something out somewhere
