Phanteks Shift X Watercooling Rig
dujames777
First time doing a water cooling build in a long time; hope you guy like it :P Took me a lot longer than expected. I was using PrimoChill Vue Coolant and it ended up completely clogged all the blocks with the "silver dust" only after 2 weeks. I ended up disassembled everything and redoing the loop.
Parts:
Intel Core i7-6700 Skylake
ASUS ROG Strix B250I
G.Skill TridentZ RGB 16GB 2400MHz
FE GTX 1080
Samsung 960 EVO 250GB NVMe
Samsung 850 EVO 1TB
Corsair SF600
Phanteks Enthoo Evolv Shift X
CableMod WideBeam Hybrid LED Strip - RGB / UV
Swiftech Drive X3 Edge DIY Kits
Swiftech Apogee SKF Prestige CPU Waterblock
XSPC Razor Neo GTX GPU Waterblock
XSPC EC6 UV Green Coolant
CableMod custom cables
Acer Predator 34 Monitor
Razer BlackWidow X Tournament Edition Chroma
Logitech G502 Proteus Spectrum RGB
Very cool, I've had my eye on this case for a while & it deserves a full under water build like yours.:) I bet it was pretty fiddly putting it together - nice job!
Thank you. Yes, the case have some down points; the main one is there almost no cable management space. There is only about 1cm in between the cover and the chassis; so I ended up using full PSU replacement cables instead of extensions. Overall, it turned out decent and I liked it.
Nice build mate, was actually thinking about something similar.
I noticed your Swiftech Drive is oriented with the reservoir facing the graphics card. Was that due to personal preference or did you having mounting issues the other way?
I used 240, FYI the whole assembly when mounted leave very little space between it and the gpu, just barely cleared the gpu.
