Feronix
For the same exact price of Corsair cx600 is the cx600M its not been released yet i think though.
It's deffinitely the better option, especially since they're the same price.
If you cannot wait though, grab a 700 Watt as I'm not sure 600 will suffice for a CrossfireX set-up, though with the prices you're looking at, you probably can't go modular.
Though, what I like about the Shinobi drive cage, is that when you take out a few of those plastig clips that hold the HDDs, you can poke a ziptie through there and just tie your cables to the drive cage.
Won't work if you're using an extra fan for bottom intake, but you don't need that anyway. I'm just here to give you options, you decide what's best for you personally
