Game Over
:huh:So I was curious how PassMark scores relate to actual real world gaming and rendering performance. I was thinking if the Passmark scores are proportional to performance in gaming and other programs like video editing and content creation then perhaps I can get better performance with cheaper parts.
For instance, You could get 2 older xenon cpus for a total of under $400 and place in a dual cpu board producing a PassMark score equal to or just a hair better than that of a single 6900K which is a $1000 chip, more than 2x the price. All other things being equal like using the same GPU such as a GTX 1080 and same amount and speed of ram (though the dual board would probably require ECC ram which maybe be a little more expensive) Would I be seeing basically almost equal performance in gaming between the two, maybe even better rendering with the dual xenon board?
Now the ram may cost a little more and the board may cost a little more so at the end of the day not sure if completed Dual slot CPU would be cheaper, same or more expensive but I am just wondering about the actual performance side. Would I get equal or better results with the older dual Xenon build than with the current 6900K single setup?
