Some progress from early last week before JR dropped this to go work on his R1.0, first testing all the correct wires were connected together as we splice all of the fans. The 3 from the rear and front 2 form one set powered directly from the PSU and linked to the motherboard via PWM for control.
Tubes cut and mounted, joining the rear side and radiators to the midwall.
The stretch of wires across to the individual fan will be partly visible through the top grill hence they were sleeved in white to blend in.
Because the back side of the front rad will be clearly visible through the transparent midwall the wire from the left hand fan was passed under and out together with the right hand fan wire.
So when observed from the front or rear of the build the fans are in the same orientation and free of little wires.
With those neatly routed it was time to trim the length and crimp both front fans together. These will plug directly into the bottom motherboard header and take power from the board just to minimize the amount of cables passing through the midwall and also allow this rad to be easily removed.
Fast PWM check from the Aquaero 5LT.
After that the pump was sleeved, the +12V and GND trimmed and terminated with ATX crimps ready for a 6-pin AUX connector and the tach/PWM diverted across the motherboard.
Front 2 fans added to the rear 3, again with +12V and GND directly to 6-pin AUX and PWM out to the motherboard.
All bundled and routed ready to fit the front panel. The 3 wires (PWM from rear fans and power for the pump) tuck inside of the front fan frame and get trapped in place, leaving the unsleeved white wires in the tiny space between the front panel and rear fans completely hidden.
The partly visible side of the rear fans...
All the ATX terminated power cables ready to go when the PSU arrived, for now bundled in heatshrink to protect our nice polished midwall. So shiiiiiny.......
Front side all wired, tubed and ready! Front tube sitting just right with the modified REVO mount.
And this is why so much work went into 7 fans, just two PWM wires are visible from the back side of the build, neatly sleeved heading to the motherboard.
Hyped for PSU and cables!!!!!
That's us for now, we collected the PSU and CPU today so more updates tomorrow!
J.
