Paralell flow in/out on bottom gpu?
grandpatzer
I want to do as this picture but having the inlet/outlet on the bottom GPU, is this possible?
I know that bleeding might be more difficult as bubbles might get trapped in top/middle gpu.
700
700
Parallel flow really requires opposing in/outlets,to have them on the same block will give you a flow dead spot as the water will choose the lowest path of resistance.
Its not recommended in the config you have chosen.
Im much more a serial flow subscriber...
The man talks so much sense!
Ive never liked this tbh.
Do you mean having paralell or my idea of having inlet/outlet on bottom card?
Ive read some articles on Paralell vs serial with good outcome for paralell:
Paralell vs serial 2 gpus
You mean the water would be going alot more to bottom cards compared to the 2 top cards?
Ive seen systems that have serial for 2 gpus but they use inlet/outlet on top card not bottom card.
Im not saying it cant be done,im saying its not ideal....
Try it out,if the temps are good,keep it.
I'd forget paralell.. serial makes more sense imo. Force dat coolant through both blocks!
I'm currently making my own serial bridge from bitspower parts. (STILL waiting on gpu blocks -_-)
It's expensive but will probs look the dogs. When mine's finished I'll post in the rig gallery to show what I mean, but basically I'm talking 2 shiny silver 90deg rotaries + 2 shiny silver multi-link adapters and a crystal link tube, diagonal. Flow goes in the left port of the 'top' card, throw the 'bridge' and out the right port of the 'bottom' card.
/offtopic
