Couldn't find a specific forum where this should go, so since it is for my WC rig, voila.
Getting a couple of these from Swiftech:
http://www.swiftech.com/HD6900-HS.aspx
They are Black Anodized Aluminum. Now, am thinking about if I can paint them white. Essentially I would have to get an etching compound and paint over the black to "prime" it, the use an acrylic or oil based white? Also, how would the heat affect the new paint job?
Just wondering if anyone has any experience with this.
Thanks,
Whaler
Thanks,
Whaler
