P5K3 and Super Talent DDR3-1600 settings
maverik-sg1
Two sets of results in regard this combo:
The best ram clocks were with these settings (saved to BIOS2):
Ai Overclocking = Manual
CPU Ratio Control = Manual
Ratio CMOS Setting = 9
FSB Frequency = 463
PCIE Frequency = 120
DRAM Frequency = DDR3-1852MHz 2T
DRAM Timing Control = Manual
CAS# Latency = 8
RAS# to CAS# Delay = 8
RAS# Precharge = 8
RAS# Activate to Precharge = 20
TWR = Auto
TRFC = Auto
TWTR = Auto
TRRD = Auto
TRTP = Auto
DRAM Static Read Control = Disabled
DRAM Dynamic Write Control = Disabled
Transaction Booster = Disabled
Relax Level = 2
Clock Over-Charging Mode = 1V
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
CPU Voltage = 1.6250V
CPU Voltage Reference = Auto
CPU Voltage Damper = Enabled
CPU PLL Voltage = 1.7V
DRAM Voltage = 2.15V
FSB Termination Voltage = 1.50V
North Bridge Voltage = 1.70V
North Bridge Voltage Reference = Auto
South Bridge Voltage = 1.20V
The best overall clock with best performance (saved to BIOS 1):
FSB Frequency = 488
DRAM Frequency = DDR3-1627MHz 1T
CAS# Latency = 6
RAS# to CAS# Delay = 6
RAS# Precharge = 6
RAS# Activate to Precharge = 18
TWR = Auto
TRFC = 48
TWTR = Auto
TRRD = Auto
TRTP = Auto
Relax Level = 2
CPU Voltage = 1.6750V
Seem that the ram was comfortable at that voltage - did not like higher volts - modded I think it can go higher.
The happy mediium would be to get nive clocks with 1700mhz ram at 1T but the setting did not allow for this - clealry if this had Nvida like ram settings then u could set the best ram timing with you best clock.
I have to say again - it was a lot of fun using this set-up, the sweetest I have worked on since re-joining the Intel fold.
Using the black slots on the board I am now up to 1920mhz 1t 7-6-6-18 Tref of 55 (using Memset, set at 60 in BIOS) with 2.15v, CPU running at 4.3ghz 480*9 @ 1.7v (undervolts though), CPU PLL is now 1.8v.
More to follow :).
Mav
Good going mav, looks like your getting the hang of things here mate, It is a very good M/B, and could be a great M/D if the bios mutures a bit more, mines still on air and can do 3.7gig all with stock settings, and rock stable at 3.6 which is very good for a Q6600 with stock air, with some volt mods to the M/B and some good cooling then there is a lot of room for improvment.
No probelm mate - 20+ hours of enjoyable benching, it's as much a record for me as it is everyone else :)
Hopefully if others embrace the same hardware it will be a guide that benefits the team.
Once I find the limit will post the final info on the max.
I forgot how much I really love this!! /drools
