Ok so I've decided to upgrade my brother's rig from 4790k to 3700x with MSI's B450 Tomahawk MAX. Of course I've decided to keep the NZXT's Kraken x72, as it's ( supposed to be ) high end CPU cooler.
Pump RPM: 2500 (silent profile)
Fan RPM: 700 (silent profile)
Idle temps: 30 C
Load temps: 85 C
Idle voltage: 1V
Load voltage: 1.5 V
Liquid Temperature ( idle ): 25 C
Liquid Temperature ( load ): 27 C
Load Frequency: 4350 - 4400 Mhz
I've upgraded the B450 MAX's bios to the latest one. I'm using everything stock in BIOS ( Except for the XMP Profile for the RAM ) Idle temps are 30C shown both in HwInfo and CoreTemp.
The thing is that the load temps are quite higher than expected, I'm using IntelBurnTest's standard profile, in which the CPU goes to ~85 C in pretty much less 15 seconds, total test is about a good 2 minutes anyway.
Idle temps: 30 C
Load temps: 85 C
Idle voltage: 1V
Load voltage: 1.5 V
