name='tinytomlogan' said:Every cpu is different dude, you have a reasonably good mobo though. Have you overclocked before? Have you read the guides?
name='tinytomlogan' said:I edited the original post thats all dude. Theres loads of guides on here in the overclocking section. Have you looked at the bios much yet?
name='VonBlade' said:If he's got 1.6v it's only because it died and he can't get back into the BIOS to lower it. Wow. 1.6v.
I think the lesson there is treat "mates" overclocking advice the same way you'd treat buying a dog in a pub.
name='tinytomlogan' said:well 1: you cant run a skull trail with 1 cpu.
2: 1.6v 24/7 would kill a cpu even if it is under water and a retailer would deffo not be sending one out volted like that. (mind you vadim went bust so maybe)
MAX safe on a 45nm cpu with good cooling is 1.45v, make sure you watch your temps. You will need to play around with the other voltages though not just the cpu matey.
