troberts008
Ok...little background...
I was previously running my e6600 on a asus p5n32 Deluxe WI-Fi AP edition with 2 gig of god knows who made it ram and had it all OC fine for a year. Then the board wnet bad during a move.
Since money was tight i replaced it with a cheap crappy asus p5vd2-vm se that offers ZERO oc or abilities whatsoever to tweak ANYTHING.
Now that money is fine....
SORRY BUT CANT POST LINKS YET >< (just just add periods after www and newegg=/)
I just ordered ...
wwwneweggcom/Product/Product.aspx?Item=N82E16813130159R
for a new MOBO
and...
wwwneweggcom/Product/Product.aspx?Item=N82E16820134632
for new ram.
Im all set on everything else....
Now for my questionish part.....
My proccessor was previously overclocked to a modest 3.0gig since the ram was crappy. didnt ever even mess with ram setting for that matter...
Now I KNOW that i can easily OC with this hardware to 3gig by simply increasing the FSB to 333 from stock 266. That would put me at 1333 FSB which is apparently the limit of this new MOBO? it says 1333+ in alot of places tho...website wise. That would also mean that my new ddr2 667 would be at a 1:1 ratio for FSB right?
SO just FSB increase to 333 would do that....what im trying to figure out now is how i can go even further.... And im assuming that this would involve adjusting my RAM speeds.... what I dont know, cant seem to find or figure out is HOW.. Meaning should I OC the ram to be faster and thus make the timings NOT 1:1? The cheap POS board im currently using till newegg delivers the MCI Platinum one wont allow me to play with any of this. I cnat even figure out how fast the ram is currently running and this pos doesnt support Dual channel either.
How does Dual channel affect Ram speed settings if at all?
Right now i THINK its running at 266 for the rated 1066 FSB of this mob and stock processor.
THe new board i would imagine would allow the ram to run at its Supported speed of 333/667 once i OC the FSB to 1333 if it doesnt just run the ram faster from the get go.
So bottom line is....CAN i and SHOULD i OC the ram...and if so....how much saftely.... i hear 400/800 is NOT hard or pushing it. but can i even do that?
IF not for whatever reason, ie mobo cant do it or its not reasonably safe, should i just attempt to push the FSB even higher? and hope theres no hole i have to push thru?
Im aware of coltage/cooling/locking pci freqs n such already, hence no mention of them.
Thanks in advance for any and all input.
I just ordered ...
for a new MOBO
and...
for new ram.
