[Orange Beast] Corsair 800D Extreme Modding Dual Loop
The fact that you were actually to keep the filters after all that work is freaking awesome! Now you even got killer sleeving to top it all off. This whole build blows my mind!
Done with PCI-E cables and working on "sleeving" the rest. I believe this cell phone pictures should do just fine, just to show progress
will post real pictures later
Looks awesome mate,love the xigmatek fans. They're one of the fans I'm interested in when I go to watercooling due to their looks (the red ones), be interested how you've found they're performance on your rad?
Awesome orangeNESS..
Keep up the great work.
Where did you find the wiring? Been looking around and can only find standard coated 18 gauge.
They work awesome and move plenty air. I have XSPC RX360 which is on the top and RX480 which is on the bottom. This rads require very low fan speeds so if you go for different radiators this fans might not have enough pressure.
I got my orange at my local graybar store at .22 a foot you can also get them at http://www.awcwire.com although their prices are not that great i would shop around google 'SRML-18' ...
Eighteen is stand for wire size you can type like 16 but 18 AWG is
plenty big in my opinion.
Good luck.
Okay got all the power cables done, looks awesome In my opinion. :)
Cell phone pics for now.
Without even trying to make it look nice still looks nice behind the motherboard, really happy with the high temp wires - very flexible. :)
And that is how wires look behind smoked plexiglass.
Little bit of reflection but you get the idea.
Better pictures coming up soon.
Sexy build man! I have always wanted to give one of the Koolance W/C PSU's a shot but i have never had the bank to rock one in a build, is it a copper or aluminum block inside?
It is nickel-plated brass inside, all the outside material is stainless steel :)
