Ok I need to know.
Pitbull#2
I need to know if i get the Haf X case I know from Toms Videos it will fit a Triple XSPC Rad. BUT will it fit the Dbl thick one and still have room for fans or will the fans only be the ones on top? I know he is Building that New Rig with a Dbl thick Rad in the HAF 932 Advance case. Ill have to see how that turns out. BUT I wanted to know if any of u have had it fit or have seen it ? Thanks guys.
There is way more room in top of the haf932 for a thick rad.
There will be some clearence issues in haf-x with thick rads.The xspc rs360 should fit though.
Dimensions(L x W x H) 21.7" x 9.1" x 23.2" Haf X
Dimensions(L x W x H) 22.70" x 9.00" x 21.50" Haf 932 Advanced.
so I dont see why that might be I guess i will find out soon when Tom builds thta new rig.LOL. I should Prob hold off on Pulling the trigger on it untill then ?...lol.
Have a look at this pic.
58mm thick rad with 120mmx25mm fans barely fits
And the haf932 has 100mm free space in top.
Realy so that is that the HAF X case? man...cant u mount fans on top under the shoud like Tom did in a Pull set up?
pitbulls right you can have the fans pulling air throw the rad from the outside of the case, leaving a gap between the motherboard and rad inside
