malibooroo
Ok, so Ive been getting the money together to finish my system, can see the details HERE
I was going to wait a bit longer to buy it all, seems i might have to buy sooner than i thought...
Last nite I was watching some shows (Chuck, if anyones a fan) and I began to smell a burning smell, very quickly I realised it was my computer, got down to have a quick look, looked ok at first glance but then noticed the liquid wasn't moving. I cut the power immediately, the GPU wasn't too hot, well not in comparison to the CPU anyway, couldn't touch the bracket of my apogee GTZ... I checked all the power connections to my pump and everything seems to be fine, tried it in a few different molex connections with no joy... Its a swiftech MCP355 and its less than two years old... It shouldn't have worn out already should it?!
I dont think any of my components are damaged thank god. but wont be able to check until I have either a new pump or my one up and running again...
Any Ideas of what could have happened, or how I can fix it?
