mayhem
We all Love gimmicks but when your gimmicks trun out to be the near perfect cooling solution for a small system such as the Odriod XU4 from http://www.hardkernel.com/ its becomes even more fun.
The Odroid XU4 is a 8 core mini PC running 4 cores at 2Ghz and 4 cores at 1.2 Ghz. The onboard active cooling ram up and down like a yoyo and when the system hits its maximum heat load of a whopping 98c the system will then throttle down to 900Mhz. this is annoying when your pushing the limits of the system.
With that in mind i decided to water cool the mini PC with the intention of just using what i had on hand and not spending a penny. Now this is fine for me since o own a company and to be as humble as possible i have direct access to lots of broken / tore apart systems and AIO's.
Any way after 4 hours worth of thinking and about 2 hours graft i present to you a water cooled Odriod XU4 running now at 38c (on full load, all 8 cores running hard).
Im still working on my concept design as we need to do some more adjustments but my final goal will be to get it cool further and also have a better way of reading and controlling the voltages. this is for no other reason but the pleasure of doing it and the fun involved.
The coolant inside is a new Nano coolant ive been working on for AIOs to make them much better at cooling... and it seemingly is doing a dammed fine job...
Some times you have to take a brake from work and play ........
