ODD pdp
AMDFTW
hey guys yesterday i started folding at 3pm and it was running till 2pm today so 23hrs i no my CPU had done 2 WU's i dont no how many my 460 did but its around 1 evry 90min
anyway last tiem i check my total pdp was arounf 15-16k pdp,i understand its points per day so in theory shouldent i off got 15-16k as they were running practticly 24hrs so one day.
but i have dont just under 7700pdp.
i maybe missing the whole thing and not taking factors into account and i am shure its done this before on the occasions i run it 24hrs
cheers
It largely depends on the WU. You could be folding a WU worth 10,000 points, but if it takes your rig 48 hours to complete it, then you won't see any points the first day, and 10,000 the second when it completes. But the average ppd would be 5,000.
So basically your ppd will be a good indication of your average points output in a day, but it doesn't always mean that's the amount of points you'll get each day. Sometimes more, sometimes less. Make sense?
I'd say that's normal. You should probably be getting anywhere from 11-19k points in a day depending on how many WUs your Phenom can finish in that time (0-2). But that's only if you're folding 24/7 of course.
well my 460 outputs 11232 pdp and my phenom outputs wround 4+k so for 23hrs is my todays points ok
That needs to change to 15000PPD
i seriously have had no other WU then these nice 912/925P WU's
man these wUS are sick,i have nearly done 23hrs work in about 9 gpu WU's lool,shame the phenom is taking its time Dam 4k pdp
its ppd
and yeah thats how i dont bother with the smp takes so long my gpu's out point it by miles and miles and miles
loool ok PPD police ha,yer but you get quite a few points for the SMP over 2k so its worth doing,when youe out or asleep
