OCing session
stevej696
Hi guys i bought a MSI P31 Neo-f board a while back and have decided to go all out on making my E2160 as fast a possible. After hours of blue screens and constant restarts i finally managed to get a maximum fsb of 333mhz fsb which means i am now running at 2.989GHz! :p
Is this a good result for a E2160?:D
Here's some core temp images
Here's idle with my antec 300 case fans all set at medium
Here's after 1 hour of orthos stress prime with fans at same level
Fan specs:
3x Asaka blue led 1500rpm fans, 2 front (intake) 1 side (intake)
1x Xigma tek xlf series 1500rpm orange led fan exhaust
1x 140mm Asaka blue king 100rpm fan exhaust
nice you still got some room for more :D what cooling u using? what voltage u get 3ghz at?
i managed to get 40c load 3.2ghz stable with true cooler.
Im using a Asaka ak965 tower cooler with a xigmatek 1500rpm 80mm fan running full speed constant, no pwm:(
To get it stable im running a 1.4565v Vcore, 950mhz@2.2v on OCZ ram (normal 800mhz)
No ,atter how much i increase the voltage i cant get a stable 3.0ghz, but still not too bad 1.1ghz over standard with those temps in summer. Roll on winter freezing weather:D
