S_I_N
Ok I’ve googled my eyes out til they’ve bled, I can’t seem to find a direct comparison. I’m currently running 6 SP120 RGB on my Corsair 570X 5 intake top/front (this was done for looks so you see the fan not the back on the top) and one exhaust on the rear. My temps are fine but feel could be slightly better. 51c cpu 43c gpu during a several hour long gaming session. They run at about 900-1000 rpm and fir the most part are quiet to me. They have a mmh2o of 1.45 which of course is at full speed of 1400rpm so I’m just licking at that max mmh2o.
Now I understand that the ML120 Pro have a mmh2o of 4.2 at max 2400rpm which is triple the mmh2o. And are reportedly quiet up to around 1200-1300 rpm which is roughly half max rpm so guesstimating it’s about 2.1mmh2o.
Ok so now you know I’ve done my research lol anybody here used the ml’s or both that can give a real experience opinion of if it’s worth it for me to change fans and would it drops temps the way my mind is thinking it should.
Other info 30mm tick rads 240 & 360 cpu 4.9 @ 1.335 vcore gtx1080 oc’d To 2139 core with no extra voltage.
