SmoulderingCircuits
I get 4 on my Phenom 965. Had it up to 4.2 before if i massively put the voltages up.
To get 4, I go:
Multiplier = 18.5
FSB = 216
Lock DRAM to 1333, but due to the overclock that will be around 1450mhz.
Then CPU Voltage - 1.45
CPU NB (i think) - 1.25
And I put my RAM to 1.55, but that will be completely dependent on your type of RAM.
The main issue you'll see is if you lock the RAM to 1600mhz because Phenom processors cant handle those speeds well enough.
This will obviously be dependent on your chip as they are all different, but it's worth a try
Different chips: can't compare.
