OC3D wallpapers
Some nice wallpapers have been done
i've been meaning to do some myself in photo shoop but I haven't been in the mood to do do it for a while.
try using max's mentalray for transpancies and caustics (glass, etc), as the built-in scanline renderer is hopeless
also, build your self a simple box, add a 'normal' moderator to it (to turn it inside-out), and place ALL your scene in it...
then bounce lights off the walls of the box, to light the scene.
this will speed up your renders, and give better looks
Thanks for the tips man! I don't really use it that much just got it to play about in, I'm sure I used mental ray to render it but thanks for the box idea, your work is awesome as i've seen in the thread
