OC3D VR Owners Thread
Your money your choice, Personally I couldn't justify 10% extra performance over the 3080 for double the price.
Yeah I know, I want one but my needs outweigh that. I think after the results ill turn my attention to the 4000 series from AMD. My 7700k Is getting dated now.
Only reason I havent moved in is because its one of the best looking motherboards out there with the built in monoblock from Bitspower.
Very pretty! I think it is doable on Maximus Extreme too, but very much officially unsupported. :D
Its quite a good performer also. The drawback however is that it doesnt have any A-RGB.. wait a minute. Scrap that, consider that a massive positive!!! :D
Well I suppose I just improved my case - thought I'd skip the NZXT smart device and power the ARGB strip straight from mobo - as it turns out, pin order was different and I burned the strip.
Oh no
Oh no
So you plugged an A RGB into a standard RGB connector and pump alot of volts through the wrong pin in the strip :D
Came across this. Looks hilariously silly to use
https://www.cybershoes.io/product/cybershoes-cybercarpet/
On further investigation it seems that the plug just needed to be flipped - but due to the holding clip there was only clearance to stick it in the wrong way. :lol:
So yeah blasted a comm rail with 12V.
Those shoes look like something which could be replaced by a pair of roller skates and some sensors. :D
those shoes, couple with MSI back pack PC and a valve index kit... Now strap them together and go skating down a street shooting zombies :D :D :D
"Why do you rent out a parking lot for weekends?"
"It's a VR thing, you wouldn't understand..."
