-•=» Project: Illuminati Unleashed «=•-
Sneaky
Just the final product of a long computer build
Complete dual loop water cooled system - all inside one case :)
Case/Components:
  • Enclosure: Custom Black Wrinkle Powdercoated Mountain Mods U2-UFO w/ Original Top - HAVE
  • Processor: Intel Pentium D 920 Presler 2.8 GHz @ 4.22GHz (14x301) w/ 1.4125v - HAVE
  • Motherboard: Intel D975XBX 975X Bad Axe Rev. 302 w/ 0908 BIOS - HAVE
  • Memory: 2GB (2x1GB) OCZ DDR2-667/PC2-5400 Platinum Enhanced Bandwidth (4-2-2-8) - HAVE
  • Graphics: Sapphire ATI Radeon X1900XTX 512MB PCI-Express x16 - HAVE
  • Audio: Chaintech AV-710 7.1 PCI Sound Card - HAVE
  • Storage: 2x Western Digital Raptor WD740ADFD 74GB 10,000RPM 16MB Cache SATA (RAID 0) - HAVE
  • 2x Hitachi Deskstar T7K250 250GB 7200RPM 8MB Cache SATA II (Backup Drives) - HAVE
  • 5.25 Devices: Black Samsung 52x32x52x16 CD-RW/DVD combo drive - HAVE
  • Power: Zippy/Emacs PSL-6701P-SATA 700w w/ Full PFC (45a 12v rail) - HAVE
  • Display: Samsung SyncMaster 940B 8ms 19” LCD – HAVE
CPU Water Cooling:
  • CPU Block: Little River Waterblocks Storm G5 - HAVE
  • Radiator: Thermochill PA120.3 - HAVE
  • Pumps: 2x Laing DDC-2TP Rev. 2 "Plus" w/ Alphacool Acrylic Tops - HAVE
  • Fillport/Reservoir: Swiftech MCRES-MICRO Mini Reservoir - HAVE
  • Tubing: Masterkleer 7/16" ID, 5/8" OD (3/32" Wall) Tubing - HAVE
  • Hose Clamps: 10x 316 Stainless Steel Worm Drive Hose Clamps 7/16" to 25/32", 5/16" band - HAVE
GPU Water Cooling:
  • GPU Block: AquaXtreme MP-1 - NEED
  • Radiator: HW Labs Black Ice Pro II - HAVE
  • Pumps: Laing DDC-2TP Rev. 2 "Plus" w/ Alphacool Acrylic Top - HAVE
  • Tubing:Masterkleer 7/16" ID, 5/8" OD (3/32" Wall) Tubing - HAVE
  • Hose Clamps: 8x 316 Stainless Steel Worm Drive Hose Clamps 7/16" to 25/32", 5/16" band - HAVE
Misc. Cooling:
  • CPU Radiator Fans: 6x Arctic Cooling AF12025 120x25mm- HAVE
  • GPU Radiator Fans: 4x Arctic Cooling AF12025 120x25mm - HAVE
  • 120mm Case Fans: 4x Arctic Cooling AF12025 120x25mm - HAVE
Wow Justin... Just... WOW!
That is by far the best setup you've created, I love it. The dual loop system is just nuts, I bet it holds some goood temps. Everything about that setup is just kill, thx for posting it up for us mate.
:yumyum:
Awsome I have been watching this for a while on XS, but man it is amazing finished and the case is just so unique.
Wow I just noticed the mosfet heatsinks on your board that is freaking awsome. Why are you usint two pumps in series? I am assuming it is for higher head pressure, is that neccessary with one block, I am not doubting you just trying to learn :)
In series is the best way to go, plus you have to keep in mind that he's pushing water through 2 res's, 2 rads, and 2 blocks... Quite a bit of stuff to keep up with :)
name='Sneaky' said:
i do... i think frag was lost in the jumble of tubing inside my case :wavey:
Ah so you've got 2 pumps in series for the CPU block and the 120.3? And then one pump and the smaller rad for the GPU?
yes sir ;)
and so far GPU idles around 37C... and never tops above 41C under load :worship:
haven't done any load tests on the CPU yet though
i think i'm officially a fan of ceramique over AS5 now :yumyum:
just a meager 3.73 on the CPU w/ 1.3250v, and through ATI CCC, the card is at 690/800 (the card i got back from sapphire after the RMA sucks at OCing... the card before was a
ing killer though :()
