Rahu X
Well, seeing as I'm in the market for some newer cards (waiting for the results on the upcoming 6970 before deciding to get that or the GTX 580), and these cards seem to be 10.5"+ in length, I've decided that it's about time to upgrade my smaller mid tower case to a full tower that has plenty of room for today's top of the line GPUs.
While looking around and doing various research on case after case, I'm sort of stuck deciding between the 3 I listed above, as they all seem to fit my tastes perfectly. So I came to you guys, the very knowledgeable community at Overclock3D.net, for help in this matter.
Anyways, I guess I'll go ahead an list some of the positives and negatives towards each of the cases.
(Also, I am American, so I apologize for the links to US sites and listing US prices if that bothers you)
NZXT Phantom:
Pros- Least expensive out of all the cases ($139.99), decent cable management, fan controller integrated into the case, plenty of space for longer GPUs, tool-less design for installing hard drives and optical drives, up to 7 fans can be installed, looks completely orgasmic
Cons- Despite having up to 7 fans cooling performance seems to be debatable, does not have a side window (even though one may be coming in the future), the only 200mm fans that can be installed on it are NZXT fans, only one fan has LEDs (not a huge con, but a con nonetheless)
Antec 1200
Pros- It is the "middle child" concerning price ($159.99), almost unmatched cooling performance, fan controllers and switches available for all default fans, despite what the pictures show the newer versions of this case do have a CPU cutout on the motherboard tray, all default fans are LED lit, decent cable management, 3 removable hard drive cages allowing for 9 hard drives in total, comes with a side window that has a slot for an optional 120mm intake fan, looks great
Cons- The oldest of the bunch (not necessarily a con), it can fit full length video cards but it has the smallest amount of space compared to the other cases, drive installations are not tool-less, only 3 5.25" drive bays, does not fit anything bigger than a standard ATX motherboard
Cooler Master HAF X
Pros- Exceptional cable management, plenty of room, great cooling performance, hot swappable drive bays, tool-less design for nearly all drives, 9 Expansion slots (not that I'm ever going to be needing that much), support for a 360 rad for water cooling (still debating on going water cooling or using the Noctua NH-D14 for my system), USB 3.0 on the front panel, comes with a side window
Cons- It is the most expensive of the cases ($199.99), the default theme is black and red (clashes with my current theme of black and blue), industrial look of it is ok but not exactly to my liking (it is kind of growing on me though), no fan controller
So, out of those cases, which one would you guys recommend? Or do you have another case entirely to recommend to me?
Thanks in advance.
NZXT Phantom:
Antec 1200
Cooler Master HAF X
Thanks in advance.
