Agost
I test fitted two rads fine - I covered plenty of reasons why it would and maybe wouldnt in my review.
Did the 3.5" hdd fit under the front 360mm rad??
I said in the video a front 360 means no mechanical drives. Its a mid tower case that costs £90 ffs.
You only have to look at pictures to see how high the first drive is. I also said IN THE VIDEO if you want a mechanical the front will be restricted to a 240 rad
Get 2 ssds and stick them on top of the powersupply cage. Boom solved.
Can always get 1tb 2.5inch drives anyway if SSDs are out of budget.
You can buy fast 2.5" HDDs (like a WD Black 2.5") with 7200 rpm. Shouldn't be slower than a 3.5" version, at least not by much. You can get two 750GB drives for the price of a good 128 GB SSD. In case you prefer speed over capacity, you could also simply run them in a raid to get more performance out of them.
That's what I'll be going for with my new case.
As for case availability; well the retailers in europe that I checked have the H440 listed as 28.02. and the Carbide 540 white at 13.02. I hope neither of those dates are true and they release it somewhere around yesterday.![]()
Nice debate on the mech drive with the 360 rad on the front, I thought they brought out some new color schemes and created all this big fuss...
I guess color is something case manufacturers wont be able to satisfy everyone's taste, but they pretty much hit the nail on the head with the white/black and black/white. I'm hanging out so much until its release, have everything on standby until then. red/black would kill on the rog or msi gaming board.
Hello Everyone,
I want to update everyone on a few items.
H440
Shipping for the H440 starts on the 17th for the White version and the 24th for the black
We are not making the Power supply shroud for other cases and It is does not come out at all.
The driver bay cage has about 110mm of spacing for a front RAD
You can install 2 X60 and a X40 into the case, or varations of that combo.
Still a 2600mm x 80mm rad a 25mm fan can fit even with all the drives populated if i read that correctly.Thats still a crap ton of rad surface area. and thats not including the top.
NZXT have said the h105 will fit... so i'm pretty sure it would.
