Thanks for the review Tom. The case looks definitely awesome, I'm so much getting the black/red when it becomes available in Norway!
Just add to baskethttp://www.komplett.no/search?q=NZXT+H440
I am really interested in this case, although I am worried about the cooling. I am starting a build and worry that 2 Asus R9 290 DCUII cards will get too hot. Any thoughts on this? I currently have a corsair 650D.
Thanks
It'll be fine. The case fans should do the job well, although remember that the DCUII likes to throw heat everywhere so you better make sure you have good ventilation.
Thanks for the prompt reply. I have an H100i that I am planning to install in the roof of the case. I am not opposed to replacing the fans. I thought maybe some corsair red and black fans to match the red and black case I was planning on getting.
If youre using the same motherboard then this case will probably be better than your 650D - the biggest difference to GPU temps is your motherboard slots. The H440 doesnt have side panel fans thankfully but the airflow though should be fine. one thing I will say is if you get black and red SP120's for the H100i - get the quiet editions and DONT use the link software - wire them to the PSU directly and use fan speed reducers (just aim for mega quiet)
Also then you have the option to kit the rest of the case out with AF120 quiet editions that have practically the exact same main design so all of you case fans will match.
It will look the nuts and be nigh on silent too if you set it up right![]()
This is good news! I was planning on getting all corsair fans and with my Asus Crosshair V Formula Z and red PSU cable this will look nice. I am going for the black case obviously.
