NZXT 810 Watercooled
Did this come in the pack with the tube res?
This is what I use to drain the loop.
The bottom part of the res, I presume where the pump is, what's the name for that, exact name please.
And couldn't you have connected the pump box and res together so it's all one big unit?
That drain bit, what's that one called where it has a valve/switch?
Sorry im really a newb at WC but I want to try it with my system.
I have exactly the same case as you and im most probably going to copy your set up lol
If you don't mind :lol:
That's a pump top.
Depending on the model, this is basically the same:
http://www.specialtech.co.uk/spshop...Top-for-Laing-D5-Pumps--Acetal-pid-15340.html
Yes with 2 of them.
It's a top for d5 pump
Maybe, but I already bought the acetal top for the D5 pump so I wouldn't spend more money on that. Just added a bitspower male/male adapter and worked fine
if you zoom in the end of fitting+valve you'll see it.
I don't mindl, don't worry :) but just an advice. I you are going to place a rad at bottom of the case try to buy it with 4 holes. Use 2 of them for the loop, another one to put the valve (lower part) and the last one just closed. It will be easier for you to drain it.
And also a res with 2 holes at the top. One for the loop and the other one to fill it.
Thanks Noz.:):)
Bonus pics hehe
The 5.25" bay area is a bit too busy for my tastes (too many knobs and display numbers and stuff),
but that's just my personal taste. I do like the bottom cutout for the fans as well as the insides,
nice work I'd say. :)
Oh no you didn't! You've just put together my dream rig! D:
I'm properly jealous and I like your build. Colourscheme reminds me of L3P's Parvum Build :) (UV Green).
thank you!!!!!!!!!!!
Averageninja, I've mixed a pastel ice white and UV laser green. It is looking pretty awesome to me(glad you like it too).
I was like ok to much white but then you did that green and while like others have said not a fan of UV you sire have pulled it off nicely. Very nice build.
oh and I noted you said you have 2 fan controllers cause you have 11 fans. Thats funny I have 13 fans in my 810 build but still only one controller :D and I'm working on removing that lol. I got 2 of the swiftech 8fan pwm blocks. Tried them with my non pwm fans and well that didnt work so when I replace them with pwmer I'll put them back in and allow the mobo to control fan speed and then maybe i can put the hot swap back on or something lol.
Thank you and yeah, too much fan controllers lol. I didn't know I could connect more than one fan per channel so...I bought two of them ahaha.
