Nvidia Titan V Specifications - Is it worth $3,000?
Well there was no mention of Ampere at all until Vega flopped. So I guess we will never know if it was a die shrink of Pascal that they were just playing with or Volta in some form. I doubt it is Volta at all tbh. Why bother? to beat yourself? if they release Volta in any shape or form they will mar the price of the Titan because people will think "Hey, cheap Volta!". If it's just a die shrunk Pascal it will keep Volta prices high, and possibly push more people into buying Titan V.
Either way whatever they do it will be winning. Intel played honey I shrunk the CPU for years before AMD pulled their Ryzen finger out. I see no reason why Nvidia would not do the same. It's paid for tech, needs pretty much no research or development (because they leave that all to the people making the shrink) and so on. Money in the bag.
I will still stick to the "We will see Volta" part though. Simply because history shows us we always have. Servers and workstations etc.. Look to those to see what is coming next etc. Same old really.
The GDDR part? yeah, any even reasonably sane person would make sure their core tech can address more than one type of memory. AMD? HBM2 is pretty cheap for them. It isn't for Nvidia, so they would have done their best to make sure Volta can use GDDR. I am almost 100% sure about that. Plus as has been demonstrated to gamers since Pascal, we don't actually need it either.
The point I am making is Ampere is Volta with all the pro stuff taken out. This makes it cheaper to produce and NVidia will be able to sell at their traditional price points for mid range and high end cards. It also allows NVidia the elbow room to continue selling Volta professional cards at a much high price point.
I don't think Ampere is Volta. I think it's a die shrink of Pascal, providing it provides a hefty clock boost. I will explain why I think it is a die shrink of Pascal....
Smaller die = less cost. Also, smaller die = higher success rate due to bad areas of silicon. As such, *if* a die shrunken Pascal can clock higher etc it will handily beat Pascal quite easily and be peanuts to make.
Why on earth would you spend time and money cutting down Volta and making it run on a different memory type and ETC if you could just use something cheap and easy?
Also, even if it were cut down Volta why would you call it something else? why not just use Volta which ATM would make cards sell more because people would know for a fact that it's Nvidia's brand new tech?
Something just isn't sitting right with me Kaap. Like I said before, no mention of Ampere before, it was not on their road map etc etc. Only mention it two weeks after AMD release the FE.
It will be really, really easy to tell what Ampere is when it launches. I am 99% sure Jim @ Adored will simply down clock it and compare it to Pascal like he did with Pascal - Maxwell. And the figures won't lie.
But yes, I am pretty confident it is not Volta in any shape or form.
Edit to add..
Also, don't forget about Ryzen mobile, plus AMD's deal with Intel on Ryzen.. Nvidia need a mobile GPU. Something Volta will never be and can never be. So what are they going to use for that? the more you shrink Pascal the less power it consumes. So yeah, we will see shrunken Pascal either way IMO.
Edit to add..
Don't forget Volta is already a die shrink on Pascal hence the 21 billions transistors on the Titan V.
I do agree clock for clock Volta is no better than Pascal but there are a lot more transistors on the newer architecture that make up for it.
I think Ampere will be very similar to Volta but designed from the start to
Use GDDR5X or GDDR6
Fab 12nm
No Tensor cores
Very few or no DP cores
Boost clockspeed around 2200mhz to 2300mhz.
I suspect Volta and Ampere have been developed together and share a lot of the same technology. As to the boost speed I quoted above one of my Titan Vs on air has managed 2060mhz and spends most of its time running at just under 2000mhz so a cut down gaming GPU should be able to reach much higher speeds.
This would make the most sense to me, with GDDR6. I'm getting the itch right now; for information, specifications, and owning one!!!
Side note @ NeverBackDown and Kaapstad: getting the hang of civilization 5 and trying (and succeeding) to accomplish multiple victory types for my Dutch civilization.
Yeah it depends on when the next series of cards release for GDDR6. Even then only the top end cards I feel like will still rock 5x.
Good job. Can always watch let's plays too if you want too learn.
