AlienALX
Well-known member
I don't know how is that possible. You can't just solder more RAM to the GPU. If it is disabled on the die that is it.
Not true. You just have to double down, hence the 16gb rumours.
https://wccftech.com/evga-launch-gtx-780-6gb-gtx-780-ti-6gb-variants/
It's been done before, twice.
https://www.scan.co.uk/products/6gb...dr5-gpu-954mhz-boost-1006mhz-cores-2304-dp-dv
Now to change the multiples? you would need to hobble the memory controller itself.
Do note, this new Micron memory coming out allows you to fit the same amount on half of the RAM chips
