d1974
GTX 980 Engine Specs:
2048 CUDA Cores
1126 Base Clock (MHz)
1216 Boost Clock (MHz)
144 Texture Fill Rate (GigaTexels/sec)
GTX 980 Memory Specs:
7.0 Gbps Memory Clock
4 GB Standard Memory Config
GDDR5 Memory Interface
256-bit Memory Interface Width
224 Memory Bandwidth (GB/sec)
GTX 980 Technology Support:
Yes (4-way)NVIDIA SLI® Ready
Yes NVIDIA G-Sync™-Ready
Yes NVIDIA GameStream™-Ready
Yes GeForce ShadowPlay™
2.0 NVIDIA GPU Boost™
Yes Dynamic Super Resolution
Yes MFAA
Yes NVIDIA GameWorks™
12 API Microsoft DirectX
4.4 OpenGL
Yes CUDA
PCI Express 3.0 Bus Support
Windows 8 & 8.1, Windows 7, Windows Vista, Windows XP, Linux, FreeBSD x86OS Certification
Display Support:
4096x2160 Maximum Digital Resolution*
2048x1536 Maximum VGA Resolution
Dual Link DVI-I, HDMI, 3x DisplayPort 1.2 Standard Display Connectors
4 displays Multi Monitor
Yes HDCP
Yes HDMI
Internal Audio Input for HDMI
GTX 980 Graphics Card Dimensions:
4.376 inches Height
10.5 inches Length
Dual-width Width
Thermal and Power Specs:
98 C Maximum GPU Temperature (in C)
165 W Graphics Card Power (W)
500 W Minimum System Power Requirement (W)
2x 6-pins Supplementary Power Connectors
* 3840x2160 at 30Hz or 4096x2160 at 24Hz supported over HDMI.
All can be found at
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-980
2048 CUDA Cores
Yes MFAA
4.4 OpenGL
Yes CUDA
Display Support:
Yes HDCP
Yes HDMI
4.376 inches Height
10.5 inches Length
Dual-width Width
All can be found at
