JesseLactin
I've been folding again and I've been getting 7200 repeatedly. I'm folding my 12th or 13th 7200 in a row (22 7200s total). I can't complain since I'm pulling ~7K PPD. Is this weird?
I haven't downloaded the V7 beta yet, but you guys seem to be getting better WU's. Pickster, you're folding the CPU on the V7 beta and the GPUs on GPU Tracker, right?
Thanks. So are you getting better results with that combination overall?
Way better. I havn't tried just folding on the CPU with V7 beta (maybe I should). But the GPU's are normal and the V7 beta client says im doing +/- 42k PPD just on the cpu, with these little work units.
My i5 laptop (2410m) went from about 4.5k PPD running the SMP client to 8k running the V7 beta.
My C2D laptop (T6100) went from 1300PPD while doing nothing bot folding to 1800PPD while folding and browsing.
It's madness!
Hey Pickster,
I've just downloaded the V7 beta and I am running the CPU. The project code is 7010 and the credit being shown is 2918.24. Is that the total credit, or does it get multiplied by 8, like on the GPU tracker? I'm only asking because the ETA is over 6 hours.
Hey Pickster,
Thanks guys. The PPD is the same as it is on GPU Tracker and it's taking approximately the same time with a base credit of 600.
EDIT: It's taking 5+ hours to complete a WU worth 3700 points
How far done is the unit?
For me it normally takes a few % to level off a decent PPD.
I did wait until 10% guys. When my PC is left alone my PPD is understandably higher at around 22K with the GPU running WU's without advmethods. I just thought that there would be an improvement with the V7 beta, and it doesn't look likely. I'm at 30% now with the ETA at 3h 41m.
Where do you add the extra flags on this client?
Thats really strange then. Keep it going and see if you get one of the 800x WUs next.
Even on the 7009 my old laptop is doing better than normal SMP but I guess different systems will react differently.
What speed is your CPU running at? Are you using all 8 threads?
4Ghz and I'll wait and see what I get next. Hopefully I can get a really high PPD like you guys.
