Noctua Nh-d14. Best ever.
SurealOclock
Thank you for suggesting this air cooler. It is simply amazing. My CPU at idle is at 10-12c. And under heavy load with stock settings on my 1090t the temp never goes over 30c. Once again. Simply amazing. My case helps support the cooling antec df-85. The exhaust air coming out of my case is cooler than the air going in. Lol. Thanks again tinytomlogan. Here soon I will be asking for some tips on overclocking.
It truley is the best air cooler on the market, definitely worth spending that little bit extra for it. (not that I have one but the reviews, benchmarks and comments are proof enough.)
WERD. And it outperforms the H50; H60; H70 and the Cool.IT closed waterloop systems.
Good buy. Get that baby to 4.2
hehe, its a great cooler. but just for your info: Core-TEmps below ambient are physically impossible. try a another tool to read out your temps and look for 'cpu temp'. your temps should be around 10-15°C higher...
as elo said, unless its about 5c in your room theres no way your cpu is only 10/12c
ignore the "core" temps and go off the cpu reading from the socket of the mobo.
Some people don't have space for a d-14, or don't like the look of noctuas so buy whatever's closest, like the h70. If i was being strict with my colour scheme i certainly wouldn't be buying the d-14.
