no sound
Rob_the_scot
I own a gigabyte h81 mobo and one day the sound has stopped' no matter what I do nothing.
1. no it isn't on mute
2.both rear and front panel audio ports have no sound.
3. yes Iv checked settings
4. removed and reinstalled drivers
5. when i plug some thing into the ports may it be speakers or headphones the pc sees they have been connected.
6.installed itunes and i got a warning saying there is a problem with my audio play back.
Im running windows 8.1
did you try messing with the options in system sounds and mixer? some times when i mess up my friends pc when i put my head phones in i have do that.
I had an issue once with windows turning off the audio in the system setup disabling it. The only way to fix it was to go into services and find the windows audio section and start the service there. Go have a look and see if it is stopped
says audio is on so i turned it off and restarted no luck maybe my audio chip is fooked
