New to Mach II
Volt
I just purchased the Lian Li/Mach II GT set-up. When Intel comes out with it's Conroe, I plan on installing that in the new PC. My question is, since it will take a while to install the Windows OS into the new PC, will the Mach II cool the CPU before I load the Mach II's software? I don't want to toast a new chip, or have the PC keep shutting down because of high temps.
Couldn't find the answer anywhere else in the forums.
hey,
congratulations on your purchase, the mach will cool down the system, then it boots it up. Your chip wont fry, as the mach will boot up the system when it gets to -33
Dont worry Volt m8 it`s very easy to set up a mach 2 gt,ive done one for the first time a few months back,just take your time and read the book a few time`s,or if your not sure ask on here as there will be plenty of people to help you out if you get stuck.
I for one will never go back to watercooling ever as the results are out of this world with phase :D
P.S wellcome to the forums :)
